transmission fluid change in raptor?
GasGasMan
You BETTER be sure the RedLine fluid is compatible with the Ford required fluid.
boxcartommie22
Colorado
explain please? both are low vis, both are synthetic, redline is a far better oil then any mortorcraft fluid. i already have redline 5w20 oil in it.
Xjrguy
Agreed. These new transmissions don't take kindly to some random fluid.
Just ask any Mazda or Volvo owner that stuck standard transmission oil in a box requiring jws3309.
AuPanda
Well-Known Member
Transmission fluid, windshield washer fluid, fluid, fluid, fluid....it's all the same in my book. Just put some Marvel Mystery Oil in it and you'll be fine.
FSM06
Colorado
PLEASE tell me you are joking.................
Nick B
You guys must drive alot if you are already talking about changing the fliud . Doesn't the manual says 60,000 miles ?
Xjrguy
It could be beneficial to get break in material out using an early drain and fill and filter change. Some will disagree and that is their opinion.
FSM06
Colorado
Here's the dip stick set-up.
[/IMG]
Cool GGM, does this mean you still have access to Ford's on-line service manuals? Is your log on still good? That would be cool.
FSM
GasGasMan
I don't have any access to the Ford stuff anymore. This was from a file I save a while back.
Logo is obsolete now.
