synthetic oil for trans
SVT_4X4
Linden, MI
You are out of your tree. Change every domestic vehicle I have owned including the Raptor to Amsoil -- never had a problem. Stick to what you know about. Making statements out of your rear is funny but some people may believe that crap lol. I drive in some of the worst conditions that exist for vehicles not NYC lol.
The Ford trans fluid is actually pretty good quality. Not going to get in a debate with you on your brand X oil, but you need to take some of your own advice.
And as for their statement about the old Ford fluid, which was Type F, that is also 100% true as many people used that usually in racing applications to firm up the shifts. It had little to no friction modifier package.
Boss Hoss
Colleyville, Texas
Hey I know you wear Ford Underwear and frankly would expect no less from you. There are much better fluids out there than the Ford spec stuff. Do not even get me started on the motor oil lol. :driver:
Glassman
Glassman
Santa Clara
I have contacted the transmission shop told him what was going on with the tranny, going to be taking it on on Tuesday. Thanks for all the input thus will give me some info to pass on to him
MTF
Celebration, Florida
How are they changing the fluid?
It does take a special machine to flush all of the fluid and fill.
And it has to be at the correct temperature.
There's a thread somewhere how it works.
YAMAHATOO
What about transfer case? what is the spec and capacity for the t-case? i was thinking of running royal purple ATF in the t-case, Royal Purple gear oil in the diffs,?
Ruger
Northern Nevada
The spec for the transfer case is for Motorcraft Transfer Case Fluid, and the capacity is 1.6 quarts. This is NOT a gear oil, it is a transmission fluid and its characteristics are not available. No kidding, I couldn't learn what specs it carries so I just went down to the Ford dealership and bought a couple quarts. It's not expensive in the slightest - $6 or $7 per quart. I think as long as you drain and refill the transfer case with some regularity (it actually has a drain plug!), I think you'll be all right using the Motorcraft fluid.
