Fuel Pump??
Juanchy21MIA
Palm Bay, FL
My truck is starting to have issues starting. I think my fuel pump is starting to go bad. I have already checked my Fuel Pump fuse and it looks fine. I just got a new Optima red top battery so I know its not the battery. So only thing left would be my fuel pump....right?
So if I do need a new fuel pump what is the best fuel pump out there for this truck. I have only heard of anyone mentioning the Livernois Fuel pump, but are there any other better fuel pumps out there?
FordraptorHero
Well-Known Member
I've heard good things about howe, i havent used it my self but have heard a lot of positive for the product.
Otis857
Glendale, az
I'd still replace the infamous fuse 27. My truck started having starting issues and I initially didnt change it out because it looked fine. I swapped it out since nothing else was working, and that did the trick. I put a mini fuse in replacing the small micro fuse because it has thicker tangs on it and Im hoping that stops the issue for good. I may still have to do a fuse relocation kit, but so far, so good.
Heres a link to the post to see if it is the same issue you are having;
http://www.fordraptorforum.com/f39/cold-starting-issue-54148/
