2018 motor knock
Jlszz
My motor is making a knocking noise only when warm. I have been searching for answers that the dealer can’t give me. Has anyone determined what this noise is exactly? I see videos with the same noise but no answers. 8k Miles
Thanks
https://youtu.be/NgmaUhEtU6k
FORZDA 1
Gloucester, VA
Does it go away with a slight rpm increase? Ive heard many similar noises caused by the belt idler/tensioner pulley. They have a steel spring inside and aluminum case that can make noise when the engine is idling. The power pulses cause minute accelerations on the crank and results in pulsing belt loads.
Booth9999
Idyllwild
Mine does not make that noise but I only run 91 , what gas are you running?sounds like you have a power stroke
93,180
56,460
khunter
