2018 B&O Stereo Forscan BREAKTHROUGH
Cioffdaddy
Edit: Added emphasis on the important part. Also, here is the link to the original mod for those who aren't familiar-
http://www.2gfusions.net/showthread.php?tid=3704
A lot of you are aware of the Forscan mod for the 2017 Raptor with the Sony stereo. I have discovered, completely by accident, that this mod is possible in the 2018 with B&O stereo as well! This is great news for anyone doing an upgrade because it makes everything so much easier, and I think has more potential for a better sounding system. I'll tell you how I discovered it, and that will help you understand why there is still some work to do on this.
I was doing my upgrade the conventional way, tapping the speaker level outputs to feed into a processor. While i was tapping the tweeter wires, I made a stupid mistake and, with the battery still connected, accidentally shorted the tweeter output wires and fried the ACM (radio/CD unit). A puff of smoke came out of the dash and I almost died :O So I ordered a replacement ACM (which took over a month to get, but that's another story) and installed it myself. I had been told that the ACM needs to be programmed by the dealer before it will work, but I decided to try it out and see if it would just work out of the box, or if maybe I could just program it myself with Forscan. The replacement ACM came with factory Forscan settings that were very different from my originals.
Long story short, I realized that I was getting a full-range, variable line level signal from the tweeter output of the ACM. The only quirks I have noticed are that the volume is not displayed on the screen, and the Sync voice volume varies with the system volume and so may be much louder than usual, depending on how the amp gain is set. Also the fader and EQ controls are disabled, but I would kinda expect that anyway. Other than that, the signal is very clean and the system sounds fantastic. I have removed the stock amp/DSP since it is no longer necessary.
I scanned the ACM with Forscan and found that there are a lot of differences between this one and the original one. I don't know which ones are necessary to make this mod work, but I assume it's not all of them.
Since they system is working the way I want, I have decided to leave it alone for now and not make any more changes in Forscan. At least we know the mod is possible, and we can narrow the necessary codes down to a few lines in Forscan. Worst case, you could make all of the changes and it should work. I'm sure someone will do more research and figure out which ones really need to be changed and how to work out the quirks. I cross posted over on the F150 forum and a guy over there has done a bit of research already: https://www.f150forum.com/f30/2018-b-o-stereo-forscan-breakthrough-411268/
I have pasted my original Forscan values as well as the ones I am using now. Enjoy!
Original_______________New
7270101 10A0 9200 0173 7270101 0000 0000 0030
7270102 0000 5F03 0093 7270102 0000 0000 0031
7270103 0000 0000 0032 7270103 0000 0000 0032
7270201 7270 2015 5B8C 7270201 7270 2010 0637
7270301 7270 3011 1446 7270301 7270 3011 1446
7270401 0001 0155 53DD 7270401 0000 0000 0033
7270501 0407 2F57 5B20 7270501 0007 2F57 5B1C
7270502 765B 572F 0793 7270502 765B 572F 0793
7270601 0B00 0A00 337D 7270601 0B00 0A00 337D
7270602 0035 005C 00C7 7270602 0035 005C 00C7
7270603 6400 5C00 352C 7270603 6400 5C00 352C
7270604 0033 000A 0075 7270604 0033 000A 0075
7270701 1B00 0A00 338E 7270701 0000 0A00 3373
7270702 0035 005C 00C8 7270702 0035 005C 00C8
7270703 6400 5C00 352D 7270703 6400 5C00 352D
7270704 0033 000A 0076 7270704 0033 000A 0076
7270801 090F 2902 1791 7270801 090F 2902 1791
7270802 1F36 4655 7AA2 7270802 1F36 4655 7AA2
7270803 0217 1F36 40E7 7270803 0217 1F36 40E7
7270804 0E27 4C7C 5B92 7270804 0E27 4C7C 5B92
7270805 400E 274C 0905 7270805 400E 274C 0905
7270806 0F29 4651 5D68 7270806 0F29 4651 5D68
it’s documented on the forscan cheat sheet for F150s. It eliminates the ACM signal mods and gives you a clean signal from the h/u to the speakers. It looked to me like this series of updates would require some sort of audio processor to fully implement, so I have not pursued it.
it was discussed briefly in @Guy’s under $500 thread.
Kbobk
There is a fella who is a forscan guru that pops in the forum sometimes. He is mostly on the F150 forum. Would be good to get his feedback. Do any other ford vehicles come with the B&O stereo?
g3sys
CT
Any update on this? Going to start to play with Forscan this weekend and planning my audio upgrade to my 18 B&O, Starting by adding subs but will need to amp some new highs sooner than later.
Thx
Cowboynch
Anyone know how to get a clean signal for a sub amp and retain the the rest of the stock system?
