Top Perch - Fox Shocks (adjusting your shocks to level the Raptor)
Raptizzle
Raptizzle
FYT
Southern CA
No worries and yeah, no complaints at all. I'm way more pleased with the ride which firms up a bit, handling, and overall looks!
I say go for it! :biggun:
BOJANGLES
Chihuahuan Desert (EPTX)
Thanks a lot. Obviously, no complaints on the top ring?
Bar
None. I don't debate what people say about pre-load, but seriously my truck rides great like this. I have run mine H-A-R-D in the dez and have zero complaints about the mod. Several months after doing it I can still say I like my truck much better on the top setting.
I'm there. Thanks again
gcmj45acp
8am - I went to my Ford dealer today as I already had an appt for an alignment. When I got there at 8, the guy said his front end tech had a Dr appt.
11:30 - the guy shows up, wheels are already off, so he pulls it all apart, goes a step further and pulls the CV from the rotor to give it more room, pulls one strut assembly out....
11:50 - "well, we are gonna go to lunch, we should have ya fixed up in a while"... ******... ok, so my son and I went to lunch.
1pm - still where he left it, within a minute he pulled the right shock assy off and went over to the spring compressor and did the adjustment.
1:15 - mounted the newly adjusted shock (didn't button it up yet)
1:30 - he's hovering around a computer with 3 others doing whatever the **** they do all day.. lol
2:30 - almost got the drivers side shock assy back in place
3:00 - still almost buttoned up, noone to be found.... lol
3:15 - pulled it out and into the alignment machine
3:45 - pulled it out and around and I paid the bill.
What took 30 minutes on the first side (if you don't count the 3 1/2 hours it sat by itself), he could have spent a total of 45 minutes in it (not including the alignment) and be done with something else, but this is "the land of manana" and nobody gets in a rush..... for nothing.
I was charged $275, that included the alignment. The service advisor keeps looking for a service report (feedback from me) sent from Ford.... he's so hot on it, when I return it, he will credit me back the $275 i paid AND full my truck up...
IDK WTF is the deal with those feedback surveys, but this guy is ******* my leg HARD FOR IT....
Anyway.... 1hr if you do it right thru, 8 hours if you spend 3 at the Dr office, 2 hours at lunch, 2 hours ******* around with your friends, and 1 hour to do the work...
********* EDIT **********
Looking at my post again, you have to wonder why this dealer could afford to pay TWO guys 8 hours each and only charge me $275....... Amazing.
What dealer did you use? My nearest dealer is Champion in Katy but, I'm thinking I might find another dealer to do the perch adjustment and don't want to get stuck at the dealer all day.
crashmc302
North Carolina
Anyone have serious issues w gettin enough adjustment out of the front end during alignment when you went top perch? Especially w the steering wheel being off, because that little detail will drive me insane. I already knocked the front end a lil out so I figured I might as well just raise the front end while its in to be aligned.
BIRDMAN
Birdministrator
Boston
it will take 2 minutes to adjust the toe so your steering wheel will be straight. mine was sitting at 1 o clock after i raised to the top perch and it only took a couple cranks to straighen everything out.
IRONMAN
Well-Known Member
MICHIGAN
Anyone know the torque spec for the Blue bolt that holds the front shock to the lower control arm. I heard 250ft-lb just want to confirm..
Madcowranch
Genetically Modified
OK
Damn, I'd need about a five foot cheater pipe for my weak ass!
IRONMAN
Well-Known Member
MICHIGAN
Well, I've just been told that it's 406 ft-lb of torque.
DAMN THATS A LOT!
Thanks pirate and Hock.
