2017 Engine replaced, same issue again. Lengthy write-up
rtmozingo
North Texas
Yeah, that would be strange if a catch can had an impact on it, as I don't understand how that would impact the cam phasers. Someone explain if able.
The idea is that the can is catching oil that would be instead feeding the phasers. I don't have a sufficient comprehension level of the flow path to be able to comment on that, tho. Someone that had a can and had the issue postulated the idea.
8WOOD
I don't think that much oil travels through the PVC system on startup and when not under load to have any impact. Plus the oil that goes through the PVC system is usually vaporized in the air from gases escaping the crankcase. A catch can only collects like a tablespoon of oil very 1000 miles, unless you have excessive blow by from failing piston rings, or excessive wear and tear on the piston and cylinder wall. The only reason manufacturers "reroute" the dirty air from the crankcase is to meet emissions requirements, in the old days they just just vented to air.
OPT PRIME
Other manufacturers use cam phasers? My understanding is that Ford came up with it, and it was exclusive to them. Pretty clever system, but complexity comes with a cost.
Variable valve timing started around 1960 and Toyota’s VVT dates back to 1991. I believe Fords first experience with this was via the Ford Taurus SHO which had a 215 HP 7,000 RPM 3.0 designed by Yamaha Marine. The reclocking of the cams is handled by a “cam phaser.”
Honda’s system (no longer used) was VTEC. VTEC varied in that each camshaft has two distinct profiles. Fingers between the cam loves and valves were activate or disengaged to control which lift profile was in use.
Even an OHV V-8 as used by GM (later LT series) have variable cam timing.
Very common. Bad cam phasers? Not so much.
k-rub
Tucson, AZ
I had two different rattles going on last year. One was at startup that went away pretty quickly. The noise originated from the top of the motor. I went in and asked them to check for PCM/TCM updates. They updated both and the top rattle went away. Haven't heard it since.
The other rattle was a similar sound but was coming from the lower part of the motor and I could hear it next to the wheelwell mostly on the drivers side. This noise didn't go away. It just kept rattling even after warm. I brought it in, the dealership diagnosed it as cam phaser rattling, and they ordered the parts. The day before I dropped it off to get fixed, my new SP 592 spark plugs arrived. I installed them and that rattle was completely gone. The truck idled, started, and drove much better. I cancelled my service appointment and I haven't heard any rattles in over a year. The dealership thinks the rattle may have been spark plug knock.
I had run a 5Star tune for a short while. I think the tune fouled the stock plugs because they were super burnt up. The new plugs made everything much better.
I have a catch can and the EBOV is vented to air now. I don't get a whole lot of oil buildup in the can but I do get oil residue on the top of the skidplate where the EBOV points.
No hesitations and no rattles. 31k miles and I beat on this truck pretty good. Now the transmission is an entirely different story...
raisins
raisins
NJ
That's very interesting how the rattles went away. Do you have a link to those spark plugs you used by any chance? It's extremely odd because I was planning on dropping the truck off today, but all day yesterday I didn't hear the rattle once. Whereas before that, I was hearing it more often. I haven't done anything besides detail the truck lol. Before I do anything else, I want to swap out the plugs for the same ones you used, maybe there will be a benefit who knows. I'll have to ask them about the PCM/TCM updates as well.
k-rub
Tucson, AZ
I made a typo. The plugs were the SP542 plugs. I'm not saying that's exactly the case for yours. But it won't hurt in anyway. I was running high boost with that 5Star tune. You can probably buy the plugs at a Ford dealership. Here's links for the plugs:
https://www.fordraptorforum.com/threads/sp542-thread.60306/
https://www.amazon.com/dp/B00OAKP3B2/?tag=fordraptorforum-20
For the TCM/PCM update your truck will need to be hooked up to the IDS system. The service advisor won't be able to see any updates from his computer. I had to convince the advisor to send the truck back to the shop to look for updates, which there were. Here's a link about that:
https://www.fordraptorforum.com/thr...st-pcm-tcm-update-version.63575/#post-1293590
On a sidenote, I don't let the dealership change my oil. Don't trust them because they didn't replace my oil filter, left the original air filter in place when I paid for a new one, and left the truck a quart low.
OPT PRIME
A buddy of mine asked why I change my own oil as we drove to pickup his truck from the dealer. He was ready to leave and I suggested looking under the hood. Reluctantly he does, dipstick was missing.
1badjk
Mississippi
I have also experienced the rattle on startup. But....
I drove a 2011 ecoboost f150 for 7 years and it did the same thing but I never had any major issues with the truck for 150k miles. I have a catch can on my raptor and it collects minimum amounts of oil over time so I can’t see that being a relative cause. I do have a little concern that a newer model ecoboost engine is having the same issues and like others have stated; I want to mod my truck but I don’t want to replace the motor at my expense. Hope all this gets resolved.
