GEN 1 Release the fuel system pressure for injecotr replacement
ivo1.cox
Tortona (ITALY)
Hello to all !!
...it's the same, " remove the fuse of fuel pump " ?
....or is better disconnect the Fuel Pump Control Module electrical connector ?
thanks to you ....and ciao ! :)
MTF
Celebration, Florida
You need to kind of hold a rag around the fuel inlet plug on the fuel rail when you release the clip.
It should not be alot but wear safety glasses.
MTF
I believe the PCM will shut down injectors when the pressure drops to protect them from running dry but it should release some pressure.
