Engine Code P008A Gen 2 2017
Jburns41
Sacramento Ca
Hi all,
Check Engine light came on and the code reader is showing P008A.
"The code P008A is logged once the powertrain control module (PCM) senses that the fuel pressure is too low within the low fuel system. Low fuel volume or insufficient flow may also trigger this code. Replacing the fuel filter or the fuel pump will resolve the problem in most cases."
The truck runs and idles fine. 85k miles. Before I replace the fuel pump, any other ideas what could throw this code?
FordTechOne
Detroit
Needs to be diagnosed, don’t just throw parts. Could be a leaking injector, pump, damaged line, biased sensor, etc.
