2011 Raptor Transmission Problems
SamSVT
Hey Everyone,
Hope to become a more frequent user here. Been lurking for a while in the lead up to the purchase of my truck but now have reason to post.
I recently purchased a 2011 6.2 Raptor. It had a supercharger fitted to it prior to purchase however just before the handover, the engine had blown (the block).
I fitted a used engine and had some weeks of good driving. Once in a while I would hear and feel a thump when changing gears (automatic) but other than that, the engine was performing well. Gear changes were becoming a little worse until the wrench came up on the dash.
Initially DTCs were solenoid E, E, E and all related to electrical and open circuit. So we replaced the mechantronics and once done, many more errors came up, Also all electrical but this time it was for Solenoid A, Solenoid D, Solenoid E, Actuator Voltage Open Circuit, Torque Convertor Solenoid Open Circuit etc etc.
Ford have said that the PCM is malfunctioning and there's no power going from the computer to the transmission.
The truck is stuck in 3rd and only moves to reverse. No other gears work.
Now If there's no power, will the truck be able to shift from reverse into 3rd and vice versa?
Second question is they say my PCM has since been updated and been replaced twice with superior PCMs.
Initial part number is BL3Z-12A650-BUA and there saying the latest part number to replace it with is BC3Z-12A650-FCNP
Googling only shows this part number for the 250 super duty. Now I get both are running the 6.2 however wouldn't more show up for the raptor related to that part? Nothing other than 250 superduty is listed in parts catalogues.
Aiming to get this sorted asap but I am not sure the Ford dealership in Dubai are right with this one.
Thanks, Sam
Raptized
Raptorida
Hey Everyone,
Thanks, Sam
I haven't a clue but I'll bump this thread for you!
biturbomg
Was the tranny working fine before the engine went? Did you do just the short block or entire motor to get running again?
t_j
Chicago, IL
