Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Wet passenger floor! AC drain?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="shthpnz" data-source="post: 225654" data-attributes="member: 2681"><p>Some days ago I discovered that the floor under the mat on the passenger side of my 2010 scab was soaking wet. At first I thought it would be a residue of the leaking third brake light, but after a good drying time I discovered that the moist comes from the front of the floor, from the AC. No cooling fluid, just water. </p><p></p><p>Is this a well known problem on the Raptor? Searching on the web learned that in earlier times the F-150 had problems with the drain being horizontal, but that should have been problems of the past I would think...</p><p></p><p>Anybody recognizes the problem and then of course perhaps give me a hint for the cure?</p></blockquote><p></p>
[QUOTE="shthpnz, post: 225654, member: 2681"] Some days ago I discovered that the floor under the mat on the passenger side of my 2010 scab was soaking wet. At first I thought it would be a residue of the leaking third brake light, but after a good drying time I discovered that the moist comes from the front of the floor, from the AC. No cooling fluid, just water. Is this a well known problem on the Raptor? Searching on the web learned that in earlier times the F-150 had problems with the drain being horizontal, but that should have been problems of the past I would think... Anybody recognizes the problem and then of course perhaps give me a hint for the cure? [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
GAMike
Spike Spiegel
lukengo
Robert Wright
14raptorsvt
Gumby
C-note
fertch13
Frogger22
redracer64
eanevarez
OEMPlus Raptor
isis
Isaac Chavez
Pismobound
NickyF25
timgoldstein7
Specialtyperformanceparts
mattl600
nikhsub1
PK37
ReddingRaptor
Beinkounter
Eisner62
Ruger
foxslayer
Chewie
MurderedOutSVT
TheC-Don
khildebr
cfmistry
thatJeepguy
taquitos
greatone99
FordTechOne
gn2hr
kappy107
Oldfart
GCATX
Teamwest
17baker
BDF
OBXRAPTOR17
sah1118
rp2024
Finlay150
stevelp99
Monkish1
Reptar854
CL4
... and 31 more.
93,459
56,740
pkenna11
Forums
Accept
Learn more…
