Tires 38PSI
HunyaKitti
Are you guys relying on the instrument gauge or using a tire pressure gauge to set the tire pressures? Is the display gauge in the truck accurate?
I use a trustworthy Tire Pressure gauge. I have nitrogen and the display will give me different tire pressures if I turn the truck on and off without driving it anywhere.
Tire Pressure gauge tells me 38. Generally the truck gives me between 36 to 40 on the instrument cluster. A mechanic I talked to said there is a +/- 2 psi margin of error.
lars464
Pa
Unless your running winter air (denser molecule movement), the weep hole is virtually useless.
