Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
Steering Stablizer?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="wiz1500" data-source="post: 443601" data-attributes="member: 2284"><p>One other thing you might want to check is the lock out...</p><p>If the right lock out is not disengaging it will create more rolling resistance on that side and cause the truck to pull.</p><p>Jack both front wheels up, start the truck and spin the wheels by hand. They should both have the same resistance in them. If one is harder to spin than the other you know you have a problem....Could be a barring or a dragging brake also..</p><p>The truck has to be running to get the lock outs pulled off..</p><p>Good luck.</p><p>The stabilizer will not help with a pull as already stated..</p><p>O and I have Toyo's with zero issues...</p></blockquote><p></p>
[QUOTE="wiz1500, post: 443601, member: 2284"] One other thing you might want to check is the lock out... If the right lock out is not disengaging it will create more rolling resistance on that side and cause the truck to pull. Jack both front wheels up, start the truck and spin the wheels by hand. They should both have the same resistance in them. If one is harder to spin than the other you know you have a problem....Could be a barring or a dragging brake also.. The truck has to be running to get the lock outs pulled off.. Good luck. The stabilizer will not help with a pull as already stated.. O and I have Toyo's with zero issues... [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
KAJRIP
G Zilla
pavendort
Pismobound
Mossy 150
FreightTerrain
DFS
boholio
HighwaySentinel
Johnny@Apollo-Optics
dj30417
4x4TruckLEDs.com
Spike Spiegel
wjoutlaw
J S
isis
elking
MeFryRice
BenBB
wyomingraptor
Ruger86
pat247
CruiserClass
shank_guru
AV67
Sozzy12
CessnaDriver
Kronos2300
gstahl
TK-421
dillard09
laramie1pt8t
tm965
nikhsub1
Derail
cdiddy4224
GLT
Admin.RealTruck
ghost410
Big Blue
ToadSmasher2K1
Dnpbakon
RaptorFun
Pikser
JustinFRC
Jay_P
k3k0a808
CoolrainRaptor
SeasickLI
DDD2019
... and 27 more.
93,613
56,899
akara
Forums
Steering Stablizer?
Accept
Learn more…
