Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
Newbie looking for feedback on seemingly high estimate after accident, please advise
Discussion in 'Ford SVT Raptor General Discussions [GEN 1]' started by DMV14, Jul 17, 2019.
  1. DMV14
    DMV14 Member
    Jul 17, 2019
    Northern Virginia
    Hello all, new to the forum, wish I was joining under happier circumstances.
    After five years of squeezing this thing in and out of tight garages and spaces with no issues, I finally clipped the edge of a wall in a tight parking garage entrance.
    The back wheel on the passenger side made square contact and the axle bent. I had it taken to a dealer and this is the estimate they gave me. I do not have much experience in the area but it seemed very high and hoped to pick your brains here before moving forward.
    Thank you for any and all feedback.
    2014 Raptor SCrew
    Parts:
    axle housing $2,421.57
    indicator $93.67
    shaft assy $353.47
    lock nut $42.27
    right spring $439.07
    shock $710.27
    U-bolt $33.37
    nut $17.57
    bracket $116.37
    spacer $21.57
    shackle $67.27
    sealant $49.47
    Total Parts $4,365.94
    labor $2,412.99
    Tax/ Supplies $349.23
    Total Estimate $7,128.16
  2. Sozzy12
    Sozzy12 Full Access Member
    37
    789
    443
    Oct 13, 2017
    South Idaho
    Seems legit to me.
  3. SVTFordRaptor
    SVTFordRaptor Full Access Member
    384
    180
    Sep 20, 2014
    I have not researched every part on that list, but the price seems about right. To replace an axle housing is not cheap. Research what a Currie rear end costs and you will be thankful that yours doesn’t cost that much.
    If you were planning on any suspension mods for the truck, then it would be a good time to go ahead and do them since your rear end will be torn apart.
    I would make sure to get a rear diff cover that has a drain plug rather than the oem cover.
    Also, I am sure your shackles were already worn out after five years of use. So I would replace the shackle on the other side too—you may want to replace the other leaf spring too. These are things to think about if you plan on keeping the truck.
    Booth9999 likes this.
  4. KCM
    KCM Member
    30
    10
    Apr 4, 2019
    California
    Buy a Currie F9 rear end or camburg. It’s actually cheaper than that. Someone said above you are lucky it’s not as much $$ as a Currie but that’s only when your linking, adding a 3rd member, or fabricating the rear I’m pretty sure. You must have clipped that corner pretty hard to break all that
  5. Marcus85
    Marcus85 Full Access Member
    102
    161
    Jun 25, 2011
    By the time you put everything you need on the Currie it's over 6k
    SVTFordRaptor likes this.
  6. SVTFordRaptor
    384
    180
    Sep 20, 2014
    What @Marcus85 said.
  7. Chiefapple
    Chiefapple Full Access Member
    292
    168
    Nov 3, 2017
    Sparta, WI
    I would definitely start upgrading as the cost won’t be much more. At the very least go to deavers or icons as you should replace both leaf packs. It won’t sit level with only one new spring spack as I’m sure the originals have drooped some.
    mpk1996 and Booth9999 like this.
  8. Kahuna
    Kahuna Boats n Hoes
    837
    727
    Aug 31, 2014
    Look around and get a used axle for $1200-1500.
  9. mp_tx
    mp_tx Full Access Member
    86
    75
    Nov 23, 2018
    Austin, TX
    Boom. Done and done.
  10. KCM
    KCM Member
    30
    10
    Apr 4, 2019
    California
    Install it yourself or have someone help you. It’s 100% bolt on. Just my opinion. If your already gonna spend all that money might as well put down a little more for some indestructible parts.
    Canuck714 and mpk1996 like this.
Share This Page
