Newbie looking for feedback on seemingly high estimate after accident, please advise
DMV14
Northern Virginia
Hello all, new to the forum, wish I was joining under happier circumstances.
After five years of squeezing this thing in and out of tight garages and spaces with no issues, I finally clipped the edge of a wall in a tight parking garage entrance.
The back wheel on the passenger side made square contact and the axle bent. I had it taken to a dealer and this is the estimate they gave me. I do not have much experience in the area but it seemed very high and hoped to pick your brains here before moving forward.
Thank you for any and all feedback.
2014 Raptor SCrew
Parts:
axle housing $2,421.57
indicator $93.67
shaft assy $353.47
lock nut $42.27
right spring $439.07
shock $710.27
U-bolt $33.37
nut $17.57
bracket $116.37
spacer $21.57
shackle $67.27
sealant $49.47
Total Parts $4,365.94
labor $2,412.99
Tax/ Supplies $349.23
Total Estimate $7,128.16
Deleted member 17706
2014 Raptor SCrew
Parts:
indicator $93.67
shaft assy $353.47
lock nut $42.27
shock $710.27
U-bolt $33.37
nut $17.57
bracket $116.37
spacer $21.57
shackle $67.27
sealant $49.47
labor $2,412.99
I have not researched every part on that list, but the price seems about right. To replace an axle housing is not cheap. Research what a Currie rear end costs and you will be thankful that yours doesn’t cost that much.
If you were planning on any suspension mods for the truck, then it would be a good time to go ahead and do them since your rear end will be torn apart.
I would make sure to get a rear diff cover that has a drain plug rather than the oem cover.
Also, I am sure your shackles were already worn out after five years of use. So I would replace the shackle on the other side too—you may want to replace the other leaf spring too. These are things to think about if you plan on keeping the truck.
KCM
California
Buy a Currie F9 rear end or camburg. It’s actually cheaper than that. Someone said above you are lucky it’s not as much $$ as a Currie but that’s only when your linking, adding a 3rd member, or fabricating the rear I’m pretty sure. You must have clipped that corner pretty hard to break all that
What @Marcus85 said.
Chiefapple
Milwaukee, WI
I would definitely start upgrading as the cost won’t be much more. At the very least go to deavers or icons as you should replace both leaf packs. It won’t sit level with only one new spring spack as I’m sure the originals have drooped some.
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Look around and get a used axle for $1200-1500.
KCM
California
Install it yourself or have someone help you. It’s 100% bolt on. Just my opinion. If your already gonna spend all that money might as well put down a little more for some indestructible parts.
