Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Need better headlights in 7 days! Help!!!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Vash" data-source="post: 1019190" data-attributes="member: 1159"><p>Just get some regular Sylvania Silverstars or similar and call it good. While higher color temp or bluish bulbs may look brighter due to color, you're actually losing lumens due to the blue filter being used on the bulbs to remove certain portions of the light spectrum. Don't fall for the "ultra white" marketing BS. I'd also stay away from anything not DOT rated etc. or any type of LED headlight bulb replacement. From the testing I've seen, the LED's will certainly be brighter up close but will lack severely in distance compared to the traditional halogens.</p><p></p><p>I thought about upgrading my bulbs initially, but you're paying money for such minimal gains that it almost doesn't make sense. After getting the OEM HID retrofits, it's like comparing a search light to a single candle light. About the only thing halfway decent on the non-HID F-150 lights was the brights. Low beam setting barely did anything.</p></blockquote><p></p>
[QUOTE="Vash, post: 1019190, member: 1159"] Just get some regular Sylvania Silverstars or similar and call it good. While higher color temp or bluish bulbs may look brighter due to color, you're actually losing lumens due to the blue filter being used on the bulbs to remove certain portions of the light spectrum. Don't fall for the "ultra white" marketing BS. I'd also stay away from anything not DOT rated etc. or any type of LED headlight bulb replacement. From the testing I've seen, the LED's will certainly be brighter up close but will lack severely in distance compared to the traditional halogens. I thought about upgrading my bulbs initially, but you're paying money for such minimal gains that it almost doesn't make sense. After getting the OEM HID retrofits, it's like comparing a search light to a single candle light. About the only thing halfway decent on the non-HID F-150 lights was the brights. Low beam setting barely did anything. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
XSTNKT
ekrause157
Rapbert
Dano182
ToadSmasher2K1
forza423
Mike27t
ricetuna
GCATX
mad man
pirates1456
dh2002
someday
8250_RPM
Gumby
CaneCorso
catinthehat85
06z
WTX
stevelp99
briksqd
bdamian
MSP
BigZaddy
NACHOMASTER
njhummer18
OxWhiteRaptor
JDizzle93
daytona1783
The Car Stereo Company
bayley_dl
ograptor
JD05
damaschke
BushwiickBill
Badboy4fun_wa
SeasickLI
Jmeo
enickes
Frofan
papalumacha
BadWRP
EagleFive
termsheet
raptorgroyper
EatonUSMC
boredm
HORN HIGH ACES
twoputtbirdie
wizerd724
... and 18 more.
93,450
56,732
The Mad Lad
Forums
Accept
Learn more…
