Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Mysterious problem
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="TheJoker" data-source="post: 609042" data-attributes="member: 538"><p>When you refuel your truck the fuel vapors are supposed to be trapped and absorbed by a charcoal canister. Then, after you start the vehicle, this trapped vapors are purged back into the engine in a controlled manner. If the purge valve sticks open, the refueling vapors can pour into the air intake and flood the engine, making starting difficult. It's called "On-board Vapor Recovery System"</p><p>My first guess would be -- after making sure all the evap and vacuum hoses are in place and the electrical connectors seem to connected -- check the operation of the fuel vapor valve assembly part # 9L3Z 9E730 and the canister purge valve.</p><p>TSB 12-3-10</p></blockquote><p></p>
[QUOTE="TheJoker, post: 609042, member: 538"] When you refuel your truck the fuel vapors are supposed to be trapped and absorbed by a charcoal canister. Then, after you start the vehicle, this trapped vapors are purged back into the engine in a controlled manner. If the purge valve sticks open, the refueling vapors can pour into the air intake and flood the engine, making starting difficult. It's called "On-board Vapor Recovery System" My first guess would be -- after making sure all the evap and vacuum hoses are in place and the electrical connectors seem to connected -- check the operation of the fuel vapor valve assembly part # 9L3Z 9E730 and the canister purge valve. TSB 12-3-10 [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
green7
riv
weldoid
Reaper_247
ktownsensation
Digipax
13mpg
Raptorman19
will535
06z
Diverdown3
got2fly
3Dog
Raptor812
2012SCSVT
iam_tylerbrown
Sidewayz
ToadSmasher2K1
mike1307
Sage
MFouts
B boyes
Badboy4fun_wa
kactux
MrMicky
FordTechOne
maritn1000
NASSTY
Finlay150
MarkOne
DaveInMn
DarinT
nookss_
AJ36_LeadFootG3
03Cobraraptor
ghost410
Shane361
alockbox
flyitaway
SeasickLI
Arizona Free
MurderedOutSVT
GCATX
RaptorFun
Hambone
zoomer41
Wartman
Aird_outSRT
Original Bronco
Socks
... and 21 more.
93,630
56,935
ID_AZ
Forums
Mysterious problem
Accept
Learn more…
