Load E Tire - Pressure Question
rayofsi
NYC
Just swapped over to new wheels/tires
What do people run for Load E tires?
I have 35x12.5R18
Thanks!
NASSTY
ME
I'd try 38-40 psi. They ride gets pretty firm with more than 40 psi. But I'd air up if I planned on towing.
BAJA1K
I am running 37-38 front and 35-36 rear on general grabber x3. I tested a lot of different pressures and these seem the best for overall ride comfort. Good luck.
R
rayofsi
NYC
Thanks! I have the grabber a/tx
Nesc204
If u below 60 psi the tread wears very fast. BF Goodwich will also tell you that. I liked the K1s much better
Nesc204
Yes 60 psi does give a stiff ride but the tires last longer. Definitely deflate them to mid upper 40s for off road. Then put back up for highway use. Otherwise buy a set of tires every 45 thousand miles
bmexline
Columbus, Oh
I have 35" Ridge Grapplers on 17" rims which are E. I am running 32 in the rear and 38 in the front. I've tried many different pressures and am finding this to be the best ride. Those stiff sidewalls allow for lower pressures.
