Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
What heck are you going to do with 80lbs. injectors on a 6.2?
Even with the Whipple SC the 63lbs. injectors proved to be difficult to control.
I don't even think the stock fuel pump is going to be enough for 80lbs.
Nothing to crazy yet I just have a procharger with no injectors and dint want to buy ID so what size you think I should go with the 63lb from ford racing.. and would the clips be the same??
Can't help you with that, I'm not sure if Procharger modifies the fuel rails.
Livernois are the people to talk too!!! Or Procharger.
I would think they would recommend the 47lbs.
If the truck is completely stock other than the procharger, I would recommend the 47 lbs injectors. If you are trying to up the boost at all you will want to build the motor. Our 6.6 stroker would work great with this.
From what I understand our injectors are longer then the ones on the GT500. I am looking at going with the ID725's for my Whipple setup, not really because of going crazy with boost but because I want to go E85
