Factory Lower Control Arms
Raptized
Raptorida
Has anyone had success cleaning these up? If so what did you use?
Jhollowell
Everett, wa
I tried using WD40 and some scotch brite. That worked pretty well but laying on the ground hand sanding was a huge pain. I finally found a set of used OEM and bought them so i could work on them off the truck. I ended up sand blasting and then cerakoting them. Turned out really nice. I’ll post some pics later tonight
Raptized
Raptized
Raptorida
Yeah that would suck. Lol
Sent from my SAMSUNG-SM-N900A using Tapatalk
Jhollowell
Everett, wa
When i get the new ones installed I’ll be selling the old ones if you’re interested in going that route. You could always pull them off. Clean them up and reinstall if you can handle having your truck down for a few days
EricM
OHIO
Flitz? That's a polish. You'll be there all day with that, and I don't think it'll work very well on the rough cast surface either. I really think you want an aluminum "brightener" like what I linked above. Spray it on, let it sit and rinse it off. Done.
Raptized
Raptized
Raptorida
Sorry I left it out. I ordered that too. Thanks again!
Deleted member 12951
Guest
Need to clean the lowers. Any good product to make the job easier?
First link not working and other goes to invalid
