Bolts and gaskets
CoronaRaptor
CANADA
Ive heard you should use the stock studs. I was going to recommend going to Mopac Auto Supply and see what they carry as I bought all my header bolts for my car there, but they were SS and somebody said not to use them on here. Worth a try!
6.2Canadian
Vancouver
2004boss
metro detroit
Did the kit come with metal gaskets? When I got my sw they didn't come with any so I bought multi layer aluminum gaskets. I think they were made by kooks. Got them from summit. So far 20,*** and no leaks
6.2Canadian
Vancouver
Ya they are metal.. Good to know thanks
Badass69
Just got my SW long tubes on today. Stock studs and then OEM metal gaskets. No leaks!
RangerRob
Ramona, CA
I used Stage 8 locking header bolts and the OEM gaskets when I installed my Kooks headers. Kooks includes new gaskets with the headers but every header install thread I read through said to reuse the factory gaskets. I ordered my Stage 8 bolts thru Summit Racing. I'd also recommend getting a set of Spark plug wire sleeves and a heat shield to wrap around your starter.
-Rob
BANE
Michigan
-Rob
I did the Exact same Thing but the oem gaskets, used Kooks
