Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
4WH not always activating and/or going into 4WL
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Curt Kautsch" data-source="post: 1461998" data-attributes="member: 40422"><p>I can provide some input here. Either one, or all of the below fixed my very similar problems discussed above:</p><p></p><p>1) I replaced the TC motor. I adjusted the torque spec to the required 89 in. lb. on all 4 bolts (i think this is critical)</p><p>2) I would suggest this to everyone. REMOVE the IWE system all together (Even you Gen 2ers). I understand that it may cause minor premature where, but Ford is the only manufacturer with this system to gain as little MPG to appease the EPA (to my knowledge). The system is garbage and needs to be gutted. (I suggest RCV rings for this $150/pair). 1 hour job if you are mechanically savvy at all. </p><p>3) User Operation and sequence of engaging 4L is critical as well. First come to a COMPLETE stop, even letting the motor and gears to spool down completely while in neutral. Second, shift in to neutral (if the cluster indicates "shift delayed, pull forward" DO NOT shift to drive as this confuses the system. Give it a few seconds to engage, and lastly and most important DO NOT depress the brake at any time as this will also disrupt the sequence and it engaging properly. Yes you will hear a slight "clunk" when engaged, this is normal. Follow the same procedure to disengage.</p><p></p><p>Hope this helps someone....</p></blockquote><p></p>
[QUOTE="Curt Kautsch, post: 1461998, member: 40422"] I can provide some input here. Either one, or all of the below fixed my very similar problems discussed above: 1) I replaced the TC motor. I adjusted the torque spec to the required 89 in. lb. on all 4 bolts (i think this is critical) 2) I would suggest this to everyone. REMOVE the IWE system all together (Even you Gen 2ers). I understand that it may cause minor premature where, but Ford is the only manufacturer with this system to gain as little MPG to appease the EPA (to my knowledge). The system is garbage and needs to be gutted. (I suggest RCV rings for this $150/pair). 1 hour job if you are mechanically savvy at all. 3) User Operation and sequence of engaging 4L is critical as well. First come to a COMPLETE stop, even letting the motor and gears to spool down completely while in neutral. Second, shift in to neutral (if the cluster indicates "shift delayed, pull forward" DO NOT shift to drive as this confuses the system. Give it a few seconds to engage, and lastly and most important DO NOT depress the brake at any time as this will also disrupt the sequence and it engaging properly. Yes you will hear a slight "clunk" when engaged, this is normal. Follow the same procedure to disengage. Hope this helps someone.... [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
doyouthinkhesawus
ToadSmasher2K1
raptorgroyper
Spike Spiegel
jekyll537
Reptar854
zachery55
New recaros
Gen1Roush
AZ Raptor
Badboy4fun_wa
Matt Pearlman
EL Snagadore
DFS
Johnny@Apollo-Optics
t34ddd
GaoKS
toys
Mrjoshiba
PD1744
rschap1
Bsbuggs
cjhoneyman
Jbultz1
Morgan
Dano182
mario500
WatFam
Sharpie69
Hard R
jhamiltonak
wheelman55
RogueClimber
TomDirt
HookEm
jdm_sixtwo
RLB18
Canuck714
Arizona Free
laramie1pt8t
Raptor812
nikhsub1
RRick
scsponger31
Jakenbake
k3k0a808
Advcgh
raptrrr
NoSleeper
cjgambill
... and 36 more.
93,206
56,485
bjorn-dpc
Forums
Accept
Learn more…
