35" spare be ok in emergency?
DEGBTI
San Diego
I am running ko2 37"s. I know people say a 37 ko2 will fit in the spare tire compartment, but it wont on mine. Hits the diff. Anyway, in an emergency can you run a 35" on the front in 2 wheel drive?
500mag
Georgia
Yes, you can. Turn off stability control.
nikhsub1
Los Angeles
I actually had the same question about this. I've owned AWD vehicles before where if the tires were off by more than 3/16", you could grenade the driveline...
isis
PA
That damages the center diff. This isn’t one of those. 2wd doesn’t care about tire sizes. Ever.
PorterW1111
Florida
i have yet to pull the trigger on buying a spare 39" so i just pack two 37s... if i get a flat ill just change 2 tires, sure its more work, but i already own the 37s...
isis
PA
unless the axle is locked then it might be upset but youd be stupid to leave the locker on in that case
Wasn’t that established as impossible in 2wd on a gen 2?
