2020 Raptor Forscan
Antho
That worked, thanks! They sent me a test version.
One more thing. Have either of you been able to get the Reverse Mirror Tilt to work on a 2020? I did all the programming I found online and I still can't get it to work. It just doesn't tilt.
the mirror tilt is silly. You have to hit the down button on the mirror while in reverse and they will tilt. They don’t automatically dip when put in reverse like most vehicles.
F
FMP
Philadelphia
What is the benefit of the programming then? Can't I just hit the down button when I put truck into reverse? Will it automatically return when you leave R?
kingcareric
Suwanee GA
You just use it when you need it by pushing mirror select button. Once you put it to Drive, it will automatically go back to normal position in few seconds. You really don't need it if you use 360 degree camera if you ask me. It is better to have then not so i did it.
