2019 front differential seal leaking
Jeremy Zacher
North Dakota
Hi guys, I have 5k on my 2019 now and found that the front end is leaking gear lube onto the garage floor. I found a seal that it is leaking from, but can someone look under theirs to see if their seal looks like this? It doesn’t look to be fully seated up against the differential, thanks.
IIIOIISTER
San Diego
Dude I have the same exact problem on my 2018 with about 41,000 miles, only started leaking recently but I haven’t hit the trails in a few weeks.
Donmatteo
Santa Clarita / Coronado
Two new accounts. Both with low post count. Both comments are about a non-existent issue for trucks they don’t own.
can I get an ip check in isle 5?
calling BS on both these “people”
IIIOIISTER
San Diego
I bought the truck used with 37,000 ish miles and just started experiencing the leak. Not everyone hangs out on the forum as soon as they get a nice truck just to stroke each other off.
JohnyPython
Canada
I had a similar leak or sweat like yours. I wiped up the oil on the underside and it seems to have stopped. If you take the rear skid plate off, be careful with the u-nuts in the frame. They’re delicate and snap easily if you use an impact.
BTW, nice comeback @IIIOIISTER haha
IIIOIISTER
San Diego
@JohnyPython I've wiped it off a couple of times and it continues to seep very slowly. Going to call the dealer to see if they can look at it today or next week.
I was under the assumption that the front diff isn't engaged while driving in 2H, which is what I'm in majority of the time (Normal Mode). Unless the torsen diff kicks in at times when the truck "thinks" the rear isn't generating enough torque? I'm sure someone with a 10LB brain can visualize or explain this better.
JohnyPython
Canada
Maybe the dealer will have an answer. Good luck and report back.
IIIOIISTER
San Diego
Appointment booked for next week.
In the meantime, took off the skid plate underneath the oil pan, hit the plastic grey seal behind the diff with a good amount of brake cleaner.
I know hope is not a course of action, but HOPEFULLY the leak was caused by some dirt trapped between the seal and the metal surface.
