2014 Ruby Red
indyraptor
indyraptor
Indiana
Congrats and welcome aboard! Great color, indeed. Nice intro and a solid 'to do' list!!
Thanks!
Anything glaring I have omitted from my To Do list? I’ve been trying to dig through the forums over the last few months to try to get my priorities straight, but I’m sure there’s things I’ve missed.
indyraptor
indyraptor
Indiana
Deavers and a bump stop kit.
With the Deavers, do people generally get the +2’s or the +3’s with the front end at mid perch?
Also, when getting the camburg shackles at the same time, do you need one pair of them, or two pairs? Basically, does each leaf spring set need a pair of shackles, or just one?
HORN HIGH ACES
Colorado
I've got +2's with Geiser Brother's springs in the front which sit approx the same height as mid perch and I'm about 1 inch higher in the back with nothing in the bed.
One shackle per leaf spring and you can reuse the OEM one's if you want.
dpbook
Minnesota
Welcome! I also have a 2014 Ruby Red Super Crew, bought from a dealer with two prior owners. I purchased almost exactly one year ago with 39k miles. Awesome truck! Gets lots of looks.
indyraptor
indyraptor
Indiana
Thanks everyone! Sorry I haven’t posted any new pictures - I’m chasing down a leak on my truck...had a small leak in the rear glass - replaced that - and replaced the third brake light for good measure, but still have the leak (it is filling up the wiring channels under the door sills and flooding into the floor pans, soaking the pad under the carpet). My best guess now is that it is leaking from the panel seam behind the cab, so I’ll be testing that theory soon. It has been filling up the channel on both sides of the truck, and I always park at home on an incline with the nose of the truck lower than the back, so it has to be a leak from the back of the truck as I can see evidence the water has run down the channel from the back to the front...fingers crossed that my theory plays out and applying some 3M panel bonding adhesive solves my issue. If not...I don’t know what else could be leaking from the back.
