+18mm or 0 offset wheels for 37's
shrive81
Hey gents,
have been searching for a bit and cant seem to get a decent answer on wheel offset. I just got a 2018 leadfoot and going to install the Icon collar and 37's. I know I have to trim but trying to decide if I want to order +18mm or 0mm offset wheels. I know the 0 will possible have a bigger chance of rubbing but was trying ot see what people have ran and works. I like the tire sticking out a little more as it is a little more aggressive just want to get good info be for I purchase.
alveolartrill
I'm running the following and I have no rubbing issues:
Method 701
37 KM3s
Fox 3.0
Front fenders trimmed
All pinch welds flatten
Stock fenders
Wfo
Syracuse
73E6B69A-28BD-45C9-9FF6-97B27F2AC590.jpeg 3ADBD79F-AFEB-427F-AF61-C5AD5B9EDE2C.jpeg 3E26C237-18DF-4725-9F3C-2005EBDDE885.jpeg I just mounted up 0 offset method mr105 beadlocks with 37” Mickey Thompson mtz p3. Minor trimming of fender liner to stop rubbing at full turn. I wouldn’t want to do any jumping or heavy off-roading without replacing front fenders. I have McNeil 2+2 on the way.
EricM
OHIO
Order the +18s if those are your only two choices. To fit best though, you should look for wheels with the factory offset.
Leftsidej
Missouri
The factory wheels are +34, so I would stay as close to that as I could if you want to avoid trimming. Mine has factory beadlocks, 37" KM3s, level kit, no trimming, and no rubbing. View attachment 121938
What level kit did you go with? Think if anyone wants to throw 37s on it’s been to stick with OEMs unless you wanna search forever for rims that may not even look as good as the beads! Great looking truck and I may have to copy you lol
500mag
Georgia
Thank you. It is a 2.5 inch polyurethane disc in front and a 1 inch block in back. I do some off-roading in the hunting fields and beach, and it is fine for that. I don't race or do any jumping.
Leftsidej
Missouri
Ride quality feel the same as OEM or is it a bit stiffer?
