There is always a need for 12v power where you don't have it. Some trucks are coming from the factory with power points and even converters installed in the bed.
Has anyone addressed the best way to get power to the bed? I found these power points that are pretty cheap and seem to be well made:
http://tinyurl.com/28ep9nv
It even has a light on the bottom.
The Hopkins 12 Volt Power Socket with Utility Light is a great accessory for tailgating, camping, boating, emergency use, or whenever you need 12 Volts of power, whether inside or outside. Plus an added bonus utility light to help you see at night. With its innovative flush mount design, no drilling is required. The Hopkins 12 Volt Power Socket is available with or without a 17 ft. power wire and fuse assembly. When the socket cover is closed, the power socket is completely weatherproof and corrosion resistant.
Features:
12 Volt Power Socket without 17 ft. power wire and fuse assembly......$12.95
12 Volt Power Socket with 17 ft. power wire and fuse assembly...........$17.95
There is also a "No light" version for about 8 bucks and change.
Falcon
Features:
- Short-proof protection from electric brake wire shorts
- Bonus utility light to help you see at night
- Features a flush-mount design
- Comes with weatherproof socket cover
- Highly durable and reliable sockets
- Easy installation without drilling
Falcon
