erichuff
any covers hold up better to the abuse of offroading then others? was looking at the roll x.
I have not had good luck with the roll-x. The bed flexes and causes it to pop at the latches and come loose. I've even held the end in place with chain but doesn't help because it still pops off. My last try is I am getting bed stabilizers and if that doesn't work, I will be asking the same question as you. I ended up taking it off on the last run.
What if you roll it up and secure it during the run?
They give you four rubber foam tubes to stick to the underside so when it is rolled it helps when hitting the rear glass. I would hate to be off roading with that moving slightly and breaking your rear window. I wouldn't risk it.
Interesting. I wondered wth those were for.
