GEN 3 Official Aftermarket Wheels Thread
MQZ
Syracuse
simarddominic
Chicoutimi, Quebec Canada
XL size. Perfect fit for 0 offset wheels.
Chuckaroo91
Boise, ID
Any photos from the side to show the "poke"?
MQZ
Syracuse
The +00 will give you a little poke. The G3 fitment seems to have a similar fitment to previous generations. These are 18x9 +1 for reference.
View attachment 325811View attachment 325813
Anyone else know what tire size we have here? Ridge Grappler 35x12.50x18?? Maybe it also has a spacer or maybe just some flare articulation from the terrain. Obsessed with this stance tho.
FmaxTurboSi
So Cal
There is a new kid in town. Tremor Wheels. The company was started by my old Method rep and he's been very involved in offroad racing for the last 30 years. Running race programs for Method, KMC and Vision.
Best of all, even as a new company they have stock on 17" Raptor fitments.
What makes Tremor Different.
*All wheels are hub centric
*All truck wheel styles are made with 2 valve holes. 1-TPMS valve & valve hole to use the Apex Design Quick deflate/inflate valve(see attached image)
*All styles are made with the “Tire Seat Channel” (see attached images), this allow the weekend warrior to be able to run lower PSI when hitting the dirt and not worry about breaking the bead as low as 15 PSI. When mounting the tire, it transitions up on a 3mm tall 45 degree angle and snaps into the bead channels on both side of the wheel.
*Higher load rated than other brands
5/6 lug stlyes;
3400 lb load rating!!! (700-1200lbs higher than other brands)
Snap in cap on 5/6 lug wheels
Hub Centric
how much do the 17" impact and shaker weigh?
93,395
56,671
IDBRUIN
