This is a one-part video of the 2022 Ford F-150 “Hennessey” Velociraptor we just completed for a complete custom stereo system upgrade. From the factory, this truck has the B&O Unleashed which leaves a lot to be desired. Shipped all the way from Texas, this truck received our "Elevated" Plug & Play package. Hope you enjoy this quick video and any questions, please let us know.
*****Equipment List:*****
Ship your Truck to our facility for this upgrade
More details on our "Elevated Plug & Play Package"
--Custom Subwoofer Enclosure for the Ford Trucks
--Custom 3-Way A-Pillars
--Speaker Adapter Plates for the Ford Trucks (8-inch and 6.5-inch)
Factory Subwoofer Block Off Plate
--Door Baffle Block Off Plates
-- Blackhole Mat - 6 Boxes
- Blackhole Tiles - 2- Boxes (144 Pieces)
--Amplifier Mounting board
B&O UnLeashed Custom Harness for Rear Speaker Connection
--Full-Length Custom Made Power Harness
--Front Speakers
Focal Utopia M (8-inch, 3.5-inch, TBM Tweeter)
-- Center Channel
Illusion Audio Carbon C3CX 3" SQ Audiophile Coaxial Speaker Kit
--Rear Speakers
Focal W-XP Utopia 6.5-inch Components
--OEM Signal Integration
Nav-TV ZEN-A2B / DSP12A-A2B
--Speaker Wire Integration
Pac Audio APH-FD02 Speaker Connection Harness
- Front / Subwoofer Amplifiers
Two Mosconi Pro Series 5/30 5ch Sound Quality Audiophile Grade Amplifier
- Rear Speaker + Center Channel Speaker Amplifier
Mosconi Pro Series Pro 410 4-Channel
--Digital Sound Processor for Tuning
Mosconi 8to12 Aerospace
--Four Focal Flax Shallow 10-inch Subwoofers
All of the tuning, installation, and fabrication are done by our team. Learn about us at
Sounds Good Stereo
Mount Juliet, TN 37122
Contact Us
We offer a wide selection of custom stereo upgrades for your Ford F-150, Super-Duty, Toyota Tundra, GMC Sierra, Chevrolet Silverado, RAM TRX, Ford Bronco, Ford Mustang and many more vehicles.
soundsgoodstereo.com
Plug & Play Packages
2009-2024 Ford F-Series SuperCrew Truck Custom Level 5 Subwoofer Enclosure Box (Including Raptor)
Are you looking for the ultimate Ford F-Series Custom Subwoofer enclosure? Not only does this enclosure look amazing, but it's also designed to deliver the best sound quality, output, and low-end extension that you won't find in other F-Series enclosures. Any questions, please let us know...
Hand-Crafted Custom Made 3-Way A-Pillars for 2015-2020 F-150 and 2017-2022 SuperDuty Ford Trucks
Are you looking for the ultimate Ford A-Pillars for your 3-way component speaker kit? If so, we have a unique, hand-made set for your truck. Includes: - New Ford OEM set of pillars & handles (No need to send yours in) - Custom Built 3-Way provision that will fit most mid-range tweeter...
Custom Made Speaker Adapters for High-End Installations - Compatible with 2015-2023 Ford F-Series Trucks, Expedition and Many More Vehicles
Are you looking to upgrade your truck from the factory 6x9-inch speakers to an 8-inch, 6.5-inch, or 6x9-inch aftermarket speaker? We have the perfect solution for those that want a rock-solid mounting platform for their new speaker system. These are not the cheap, flimsy speaker adapters you...
2021-2022 Ford F-150 B&O Subwoofer Block Off Plate for Rear Wall (Includes UnLeashed)
Upgrading your 2021+ Ford F-150 B&O Stereo system? If so you will need this plate to block off the factory subwoofer hole on the rear wall. This hole is open to the exterior and this custom-made plate along with the laser-cut gasket is the perfect solution. It is CNC machined in-house from...
Custom Made Door Access Block Off Plates - Fits 2021-2022 Ford F-150
Our best-selling 2015-2020 F-150 item is now available for the 2021 Ford F-150. If you know what these are, then you know how much better they make your stereo system sound. If you have no idea what you are looking at, it's a custom-made plate that blocks the factory vapor paper hole and...
Blackhole MAT Self-adhesive Three Layer (4.5mm thick) Damping Material (Per Sheet)
PRODUCT A self-adhesive three-layer (4.5mm thick) damping material consisting of 1.5mm Butyl rubber, 0.05mm aluminum constrained layer damping, and 3mm closed cell damping foam. USE Designed for damping metal and removing unwanted vibration from a less than perfect enclosure (your door). The...
Blackhole Tile Coated Water Resistant Multi-layer High Efficiency Acoustical Absorption Pads
Available in multiple quantities packages, choose what best fits your needs below. Each individual tile is 4” x 3” x 1.5” A coated water-resistant multi-layer high-efficiency acoustical absorption pad with a pressure-sensitive adhesive back. USE Ideal damping for enclosures exposed to the...
Custom Made Amplifier Rack/Plate/Board - Compatible with 2015-2024 Ford F-Series Truck
Looking for a secure place to mount your aftermarket stereo equipment in your 2015+ Ford F-Series SuperCrew/SuperCab Truck? If so, we have the perfect solution.Custom-made by our team out of premium HDPE which provides a strong, stable platform for your gear. This mounting system uses factory...
Custom Radio Integration T-Harness for B&O Unleashed Model Vehicles - Compatible with 2021+ Ford Vehicles
Custom made in-house by our team T-Harness for B&O Unleashed factory systems in 2021+ F-Series trucks. This harness is designed to provide you with the factory rear speaker and tweeter signals to amplify along with the speaker wires to connect to your crossovers/amplifier to power these...
Full Length Power and Ground Power Cable Kit (Designed for 2015+ Vehicles)
-20' Power Copper Wire (dressed in Tech flex)-20' Ground Coppe Wire (dressed in Tech flex)-Littelfuse OEM Style MEGA fuse holder and 150a fuse-4 1/0g 5/16th's ring terminals-2 1/0ga Glands/Grommets-10 8" Tie Wraps
--Front Speakers
Search: 31 results found for "Focal Utopia M"
-- Center Channel
Illusion Audio Carbon C3CX 3" SQ Audiophile Coaxial Speaker Kit (Each)
Illusion Audio Carbon C3CX 3" SQ Audiophile Coaxial Speaker Kit To develop this new Illusion Audio speaker line we combined our decades of experience manufacturing high-end audiophile speakers with our passion for maximum performance mobile audio. The development process covered several years...
--Rear Speakers
Focal 165 W-XP Utopia Elite Series 6.5-inch Audiophile 2-way Components
Focal 165 W-XP Utopia Elite Series 6.5-inch Audiophile 2-way ComponentsThe next in line after our passive 2-way kit 165W-RC, a leading product heralded for its performance for several years now, the 165W-XP integrates our exclusives technologies: TMD® surround, progressive spider, ventilated...
Factory B&O Including Unleashed Factory Stereo Interface for Complete Upgrades - Nav-TV ZEN-A2B
The Nav-TV ZEN-AUDIO DSP6A-A2B processor seamlessly converts 2018+ Ford factory A²B® (Automotive Audio Bus) to 6-channel analog RCA and TOSLink output. Adding aftermarket amplifiers to the OE B&O or Revel amplified SYNC3 system has never been so simple. This module integrates directly with the...
Pac Audio APH-FD02 Speaker Connection Harness - Compatible with 2018-2023 Ford w/B&O Amplified System
Simplify your amplifier installation with the AmpPRO Speaker Connection Harness. The AmpPRO Harness (APH) enables you to simply plug into the factory speaker wiring harness, avoiding cutting the original wiring or running aftermarket speaker wires throughout the vehicle. Easily feed your...
Mosconi Pro Series Pro 530 5ch Sound Quality Audiophile Grade Amplifier
FEATURES: 5 channel amplifier Available in Black/Silver finishing SPECIFICATIONS: Low Pass Filter 40-220 Hz Target Powers 95×2 + 185×2 + 660×1 Watt @ 4 Ohm 150×2 + 290×2 + 1030×1 Watt @ 2 Ohm Input Sensitivity (Power rating ref) 0.35V ÷ 12V (5.3V in DDSP mode) [CH1/2/3/4] 0.14V ÷ 5.9V (3.1V in...
Mosconi Pro Series Pro 410 4ch Sound Quality Audiophile Grade Amplifier
FEATURES: 4 channel amplifier Available in Black/Silver finishing Power Rating: 120 Watt per channel @ 4 Ohm < 1% THD+N Sn Ratio: > 74 dBA / >95 dBA (DDSP) (ref: 1 Watt into 4 Ohm) Click here to download the Specifications (*) VERY IMPORTANT NOTE – READ CAREFULLY4 Ohm ST or 8 Ohm BTL –...
Mosconi 8TO12 Aerospace Digital Sound Processor for Audiophile Grade Stereo Systems
FEATURES: 8 channel input 12 channel output Digital input and output (Toslink) Coax input (RCA) Highest resolution, e.g. time delay in 0,02 msec/step All settings in real-time USB and optional BT adapter (MOS-BTM), for adjusting by PC, Android and BlackBerry (*) smart phone apps Low-Level or...
Focal P25FSE Flax EVO Series Shallow 10-inch High-Performance Subwoofer
In addition to its 560-watt power and its Flax cone for a natural sound, one of the key features of the P 25 FSE subwoofer is its slim design, making it light and even easier to install in your vehicle. Its built-in motor adds to its compactness, without compromising on the power delivered. Its...
Sounds Good Stereo
Sounds Good Stereo - High-End Custom Car Stereo Solutions
