You can use a N Fab bracket, a 30" will direct fit, you can put a 40" on the same bracket, but you will need to lengthen the mounting feet as they just aren't long enough. translation is you will need to weld additional length onto the brackets.
That's what I did, the project is still sitting on my bench because I haven't had the time to mount the equipment, otherwise, mine is ready to go, just need some more time in the day.
As far as bolting directly to the bumper, you would still need to mod the brackets, the OnX6 is pretty deep, but I think it could be done, I wanted a less permanent solution just in case I don't like it on the front of the truck.
