Change Color of “Mood Lights” Using Sync 3??
WillieFlo
Houston
Does anyone know how to change the color and brightness? I searched through all the menus and couldn’t find the submenu where to change on the Nav screen or the Gauge screen.... I want to change the mood lights to Red.
Quaesta
You can’t change the color through Sync. Not sure if you can with Forscan. Brightness is adjusted by using the dim control for the cabin interior.
Raptorguy1
On the 18 at least, you can forscan the menu to appear, but it does nothing unless you change all of the lighting components to what was used in the 2017 trucks. There are several threads that describe this and the part numbers needed to make the changes.
Johnkn
LaPlata, MD
Not sure of the 2018, but on a '19 the brightness is changed on the same screen as the audio, vehicle settings I believe. The color cannot be changed w/o changing LEDs
Johnkn
LaPlata, MD
Yep, My wife's Platinum Explorer will change interior colors as would my Platinum Expedition, but not my 2019 Raptor
Raptorguy1
I also had a Platinum Expedition and Platinum Explorer. I miss not being able to change the color. I wanted to set them to orange, but seems like too much work to change everything over to 17 parts.
