20 x 9.5 with +15 offset rubbing issues?
CanuckRaptor
I'm planning to go this route:
20 x 9.5 +15, using 35 inch BFG KO2 tires, will I have rubbing issues?
Thanks guys
brettmess24
You mean 35? They will rub the inner plastic but not terrible.
NASSTY
ME
Nope..
They will stick out .79" further than stock.
Stock offset is 35mm. So this would be a 20mm difference.
Nope, you didn't factor in that the new wheels are 9.5" wide and the stock wheels are 8.5" wide. :biggrin:
AndysLog
Moro IL
****** slinging **** in this thread.
still cracks me up most people go full retard when it comes to wheels.
you should get the 33s.
ChevyChad
Doesnt matter. The CENTERLINE of the wheels and tires will be .79" out further. And since the tire is wider than the wheel, then the outer most part of the tire will be .79" out further.
---------- Post added at 09:18 AM ---------- Previous post was at 09:02 AM ----------
The wheel will be shifted out further than the tire will be shifted out, but what really matters is the total difference in centerline- which is the difference in offset. Hopefully you can make sense of this example:
http://www.fordraptorforum.com/1158642-post581.html
93,202
56,485
bjorn-dpc
