What fog lights have the amber backlight?
j_waldrop3
Seneca SC
The only ones I have found after doing some searching on here is the rigid radiance? Are there others and if so can you attach pictures im looking at adding some fog/fog light kit. Thanks
Baja Designs
Baja Design also have amber back lighting.
@Baja Designs
Hey,
we do have some models with amber back light which would be our Lp pro series and s8 series. They aren’t usually used as fog light do to the amount of lumens they put out. We do make fog pocket replacements for the raptor, but they do not have amber back light.
Feel free to let me know if you guys have any questions.
Best,
Brahian
J
j_waldrop3
Seneca SC
I have Diode Dynamics. The SS3 max lights are bright AF. 4x4truckleds.com have a nice harness with a BL wire. You can add that to SPV's DRL marker light harness and its simple plug and play. Backlights will be on as DRL.
Do you have any pictures of them on? I get what you’re saying with the wiring would like to seem them on the truck and light output pic if you have one. Thanks
Specialtyperformanceparts
Hey there!
We would love to help you build your ideal fog setup! We have the options to do Rigid, Baja, Diode, Morimoto, or KC Hilites. If you want to put backlit lights down there in the pocket, your main choices will be between Rigid and Diode because the backlit lights available from Baja wouldn't be able to fit down there in the pocket.
All of our fog kits now come with our Patented Plug-and-Play Harness System, which is the highest quality and easiest to install harnesses on the market as far as we have seen. Unlike most other harness available on the market today, all of our wiring is coated in a heat-resistant, flame-retardant material, as well as loomed with a heat-resistant loom.
Check out this video we did where we compared our harnesses to others on the market when applying heat and fire:
We can fully customize your kit to include whatever options you need/want to create the setup you desire. We do offer a backlight harness that is designed to work with our Triple Fog Harness to put the amber backlights on with the parking/marker lights.
Also, we currently are participating in a rebate program for the Rigid Radiance and Radiance Scene lights that allows you to get back an additional 15-20% rebate post-purchase on the cost of your lights. That has been a popular offering to have for our customers this year.
If you would like to see what the Rigid Radiance/Scene Kit looks like on a Gen2 Raptor, please check out this link:
If you want to see what the Diode Kit looks like on a Gen 2 Raptor, please check out this link:
You can further research the similarities/difference between these lighting options with our videos on our Youtube channel. They have been really helpful to a lot of customers when it comes to the decision process, as well as for full install walkthroughs for our products.
Here is the link to our channel: https://www.youtube.com/@jtrischler/videos
Keep in mind, we can easily customize any of these kits to your liking. So, if you don't see the combination you are wanting, just let us know and we will create it for you.
Pretty much anything we put in our kits is almost always in-stock and ships within 24-hours of purchase using UPS.
We would be happy to work with you on your build and grateful for the opportunity to earn your business.
Please don't hesitate to reach out to us via call or text at (317) 934-6778 with any questions, comments, or concerns. We can even build your cart out for you if you'd like.
We hope to have the opportunity to work with you on your build!!
Have a great day!
-Sidney @ SPV Parts
