Well, 3 days at the Dealership and Ford Engineers are....
Kowboy17
in an FBI van
Here we go.
Last Thursday, driving down hwy in cruise, truck goes from 70 to 40mph, go to get on it, WRENCH & ODB light. Drive to dealer and the saga begins.
Code: Misfire on FordPass
Dealer starts down the road of (with Ford because as everyone is saying, Ford Engineers are figuring it out also). Waste gate adjustment (TSB) = nothing
I talked to the mechanic and he was pissed that the wiring diagrams are off since it's a new engine (side bar). Now it's on to wiring etc and they ordered something Ford advised concerning the throttle somewhere. Ford is closed today so the part won't be here till Wed. I'll keep everyone posted and detail the fix and codes when it hopefully gets back on the road.
P.S., Also had to fix 'the pan' while they were under there...lol. ( I had the same pass bolt leak from the pan and noticed it when I did the oil change).
I will say this though, the truck looks awesome sitting in the bay next to a Focus...lol
Kowboy17
Kowboy17
in an FBI van
91 or 93 Octane only from SHELL / MOBIL / EXXON
---------- Post added at 07:46 PM ---------- Previous post was at 07:45 PM ----------
Oh by the way. Also got a code for 4WD / AWD malfunction which wasn't being used (never have with only 3K miles thus far) and it went away after I stopped the truck, turned it off and then cycled it back on.
dlbb
so cal
i'm curious if there are codes set from the factory? reason i ask is mine had some dtc codes already stored when i hooked up the laptop and forscan. i cleared them and went on my way. no wrench or anything else. will recheck tonight after the wife gets home.
Sasquatch77
Banned
Truly, i bet you do have a condensate issue in the intercooler if you have a misfire code. Do yourself a favor and read up on the completely unresolved ecoboost condensate fiasco.
dlbb
so cal
holy chit what size drill bit was that? 3" lmao. tbh i would go aftermarket before i drilled a weep hole.
Kowboy17
Kowboy17
in an FBI van
Hopefully we'll find out shortly enough. On the bright side, if this doesn't work out, I've got the biggest and best looking 6K pound paper weight in the neighborhood.
dlbb
so cal
fat chick in the bed for traction? i calculated out at 5851. 7050 gvw - 1199 payload. was actually shocked cause it saves me about $200 a year in registration. had the stupid weight fee on my 14 lariat heavy duty cause it was over 6k
pjones
This is just an internet forum, and if he/she is so weak that my little suggestion is enough end it all, well, better stay off the internet.
Members online
93,202
56,485
bjorn-dpc
