Very loud in cabin at speed
SRQ_Raptor
Sarasota, FL
Searched but didn’t find anything on this.. Currently on a road trip, and it seems like any cruising speed above 60mph, there is a very loud hummm inside the cabin. There is also very slight, what I would describe as high frequency vibrations, throughout the steering wheel and blinker/wiper stalk. The truck is a 2019, 35k miles, on original the BFGs, I have owned it since 29k miles. The tires are almost ready to be replaced so I expect a decent amount of noise from them, but what is going on seems very excessive. I’ll upload a video to YouTube and post here if needed, but has anyone else had a similar experience/issue? I know wheel hubs have not been a largely reported issue but that would normally be my first guess, but I had a reputable shop do a pre-road trip inspection before I departed, and they found everything to be in good order.
goblues38
STL
There you go.
If the tires are not rotated religiously through all 5 (spare) at 7,000 miles...they cup very bad. cupping = noise and vibration.
even with a 5 tire rotation, any light off roading...BFG will rarely last beyond 40,000 miles. There may be tread left, but the ride is so poor you have to get new tires
SRQ_Raptor
SRQ_Raptor
Sarasota, FL
There you go.
Putting new tires on ASAP. I always do a 5 tire rotation on my vehicles but I’m afraid the previous owner did not. Hopefully the spare is still usable. I find it interesting that BFG puts a 50k mile warranty on these tires when they’ll never reach that and still be somewhat safe to drive on.
goblues38
STL
yeah....there are a few threads about it......they still have tread...but you can actually see the cupping...if you were 100% off road...they would be fine....but on the highway...no bueno.....welcome
SRQ_Raptor
SRQ_Raptor
Sarasota, FL
What kind of tires are the mall crawlers running? I off-road maybe only 10% of the time I use the truck. Seems like the BFGs, as much as I like them, aren’t the best choice.
nikhsub1
Los Angeles
Does it make the same noise in 4A? I would test that at speed... if it does NOT, replace the IWE check valve. If the noise is still present, likely a wheel bearing. My driver side bearing when t!ts up at 30k miles... if it is, you should be able to notice which side it is coming from. I suppose it could be the pinion bearing too, but unlikely.
nikhsub1
Los Angeles
My Cooper AT3 XLTs are the best tire I've ever run on a truck... super quiet, E rated, very good offroad - marginal in mud though...
Old-Raptor-guy
USA
Please show me any tire that lasts as long as the warranty says it will.
The whole mileage warranty is a marketing/sales gimic.
Normally any tire will fall short by about 25%. So you go to claim the warranty and they prorate it. You got 75% life so you have to pay 75% of the new tire.
This is basically a buy 3 get the 4th one free coupon. Are you really going to throw $250-300 away and switch tires, of which you would have to pay 100%.
Unless you are really disappointed in a tire it sure makes it hard to change brands.
Makes it easy to stay brand loyal though.
Sig Fanboy
WV
If your truck is a Scab I’d check the door hinge bolts for tightness. It’s pretty important for the door to make good contact to the seals, if not, you will get a lot of noise in the cab. It’s likely tire noise, but doesn’t hurt to check.
