Turbo gen 1
ramo
UAE Abu Dhabi
Hello everyone
This is my first, and im hopping to get some some help !
I built my dream machine in the UAE Abu Dhabi, but I'm having problems.
Big single turbo gen 1 (6.2) currently on 9psi,
But the ecu has failed, or atleast that's what iv been told by the workshops. The wiring harness is currently under investigation, doing what I can not to fry another computer.
Can anyone advise if I can get a f250 6.2 ecu would work as a replacement as it's much cheaper. Or can someone recomend any other cheaper then flagship1 (1000usd before shipping) would be. Car has been parked about 2 months now waiting for me to find it a new ecu.
FordTechOne
Detroit
@FordTechOne check this out lol
A bricked PCM? :think:
PCMs are generally not compatible across models. I would recommend ordering the correct module from one of the online Ford vendors that ship internationally, like Tasca Ford.
The wiring should be inspected before ordering a PCM, what are the symptoms and DTCs?
R
ramo
UAE Abu Dhabi
Not a complete brick but yes bricked
So if u disconnect the battery and let it reset it works all good sometimes one run sometimes 10 but once it starts it will shut off when coming to a stop / have a sudden momentary loss of power then get the wrench on the dash (if u turn it off and on it goes back to normal)
Also the symptoms might show at startup or after a long drive.
Strange thing is iv gotten different codes p060a / p1674 / u0422
Regarding the wiring harness the only thing we have done is extend one O2 sensor (it's only running on one) and extend the intake sensor (MAF)
Also my tuner used SCT
CleverGirl_
Cabin Clown
I would get a new ECU and have it dyno tuned by someone who does those insane Patrols. Don't rely on SCT.
Maybe get a standalone like what holly makes? The name escapes me, but Cletus McFarland uses them in all his builds.
Nex
RIP CoronaRaptor
Washington State
Other then what I did reloading the original tune, can the ecu be refreshed or updated
You would need to check with Ford if the software is up to date. Check all of your wires and connectors. Make sure ground wires are hooked up.
Are you using the stock throttle body or aftermarket?
FordTechOne
Detroit
Those DTCs indicate a corrupt PCM, which can be caused by the aftermarket calibration, low voltage to the PCM or high resistance in a PCM ground, or electromagnetic interference.
Start with inspecting the spark plugs, boots, wires, and coils. A failing ignition coil can generate enough EMI to cause those DTCs to set, especially cylinder 4 which is closest to the PCM. Adding forced induction wears the plugs much more quickly, and the combination of worn plug(s) and old/failing coils can induce this exact symptom and DTCs.
