Toyo MTs rubbing?
toolfan94
Eagle Pass,Texas
Hey guys,I recently put some 35" Toyo MTs on my 13 SCREW and I'm loving the nice aggressive look but for some reason they rub on my inner fender lines when ever i make a full right or left turn. Is this normal or could an alignment issue be the culprit? By the way I'm also running OEM wheels and on stock perch.
Huck
Chicago Sw Burbs
Yeah they will rub a bit on stock wheels.
If your all stock thats the problem. Otherwise caster can be an issue.
oxfordraptor
^ Is that only Super Crews or only with stock SVT wheels and not the beadlock capable wheels? I have 35x12.5x17 Toyo Open Country MT's and no rub on bead lock capable wheels truck is a SCAB
Madcowranch
Genetically Modified
OK
Go to mid perch
LS3 CJ7
Ponte Vedra Beach, Fl
I have 35" Toyo MTs on 18" BMF novakanes with no rubbing. I'm at factory perch but considering mid perch
WNCHSTR96
Athens, Alabama
Is it in the inside front corner tabs of the front fender wells? If so that's seems to be a common issue and can be corrected by either trimming the plastic a little or as I did, just drill a little hole in the liner and attached some fishing line to keep the corner pulled fwd some. Mine (stock tires) would rub when turning after long interstate trips. REALLY loud when backing BTW. (I think it was mentioned in another thread, hence how I found out)
Madcowranch
OK
Mine too. http://www.fordraptorforum.com/f39/loud-rubbing-noise-when-turning-2258/
Luke13
Norco, Ca
Mine too, I'm on methods however on mid perch
