Steering wheel play
Bajaking
Boxford MA
Hi, wondering if anybody else is having an issue with the 2023 37 package steering wheel. There is play in the wheel only when it’s top dead Center about an inch on each side left and right when you move the wheel you can feel it also. You can also hear it when you quickly move the wheel back-and-forth.
Wichadicha
Georgia
Might be steering wheel bolt. When I remove mine to install heated feature, I was not impressed by how much wiggle room in the wheel to steering column play there was (it is not splined). Once the bolt was tightened, it was better but if that bolt slipped even a little, there would be play in the wheel for sure.
