SPD trombone install question
Birdnutz
Az
I’m having a heck of a time aligning the flange up. The bolts that came with it seems to not have enough threads. The stock ones are threaded all the way up the shaft of the bolt. Anyone else run into this?
BoostCreep
SoCal
Mine didn’t come with any bolts for the downpipe flange, it only came with two nuts and you reuse the factory bolts.
Once you have the passenger side in the passenger downpipe, the drivers side flange should line up.
Birdnutz
Birdnutz
Az
Thanks, weird mine came with them.
NateMob
SATX
A picture is going to help us help you more. I did one of these last weekend and didnt run into any issues.
TXRaaptor
@thebeardedbrand
The Woodlands, TX
So I had some fitment issues. What I found was that I had to expand the opening so the trombone could fit over the pipe coming from the downpipe end of the system. Once I expanded the opening, it popped right on and alignment was perfect. I posted a thread about it also, be quicker for you to search SPD and it’ll come up under my name I guess. Good luck! Sounds awesome once on!
KOK JR
KY
Used the stock long pipe clamps. Had to trim one of the Borla pipes. Installed easy after that. Very nice sound at WOT.
