Hi, thanks for trying to help. I absolutely know that the upper right gauge is selectable between trans temp and boost. When I purchased the truck it was on trans temp and I was able to change it to boost.
Since that time I've learned how to configure the 'Raptor Gauges' which are round and appear as analog between the tach and speedometer. I currently have them set up as vacuum/boost and engine oil pressure but they are selectable to about a dozen different gauges, but you can only select up to 2 at a time. I now want to change the upper right gauge above the speedometer back to trans temp. I've been through the manual multiple times, mine appears to be a 'type 3' display. My truck is a 802A with technology package, but the screen doesn't match the manual.
Normally I'm in 'my view' bottom pic.
When I select 'gauge view' it shows the raptor round gauges I've selected and configured. I've even tried deselecting them to see if I could get back to the upper right trans temp/boost, no luck. Sorry for crappy cell pics
