Rigid Cargo/Bed Lights installed
justvettn
justvettn
GTA
The new A-series was released but my supplier still knows nothing about them.
getbit
Austin, Texas
I think Warm White would be brightest, then Natural White, then Cool White.
Actually, it should be the exact opposite.
The higher color temp (cooler/whiter color e.g. 4800K) will project a more visible light spectrum, as well as having a higher lumen rating, while using the same wattage (or less sometimes) than a lower color temp (warmer/yellow-orange e.g. 3200K).
Each model (black/white/Tri-Plex) has a powder coated cast aluminum housing with the Tri-Plex finish being specified for salt water applications.
Nick@Apollo-Optics
Houston, TX
Actually, that's incorrect. The lower the color temp, the more usable light you have. Like HID lighting, 4200K will have significantly more light than 8000K. The higher the K, the farther you get from sunlight (3200K) and the closer you get to dark blues and purples (10,000K to 12,000K).
justvettn
justvettn
GTA
The A series lights are out now but wondering what the Tri-plex is all about?
