Rear endish noise
Lift_to_suceed
Grande Prairie Alberta
2018 SCAB with 2700km been stretching its legs off road pretty good recently and having a blast. Now when I start it up it sounds like the fuel pump is going mad, put my hand on the tank and couldnt feel any vibration. Or maybe its vacuum noise of some sort? Only in park and below 20km it happens, drive off and the noise stops. Only comes up after startup. Any clues from anyone? Truck is sitting at 1/2 tank currently, I will try and get sound of it tomorrow and post it in here.
Thanks!
Sent from my SM-N950F using Tapatalk
Sozzy12
South Idaho
IAC valve? They are known to make a humming noise at idle when they get gummed up some. Not sure if these motors use the same system as years past. Sometimes you just need to clean out the valve with some brake cleaner.
L
Lift_to_suceed
If it does have the same it would make sense, was in some gummy mud. Ill do some digging, thanks!
