GM3SF
- Joined
- Oct 27, 2012
- Posts
- 189
- Reaction score
- 222
Can you walk us through your sequence of setting up the WDH and air bags please?
Curious as to how you set your bars and add air, or vice versa... I can't get my head wrapped around it.
I've never tried both, have only read about "how difficult it is to use both" and never felt the need for air after properly setting up the WDH.
Great feedback, and 13mpg is incredible! What were you getting with the GEN1 anyway? Whenever I've pulled that kind of weight at any kind of speed, I'm under 10mpg with my 6.2.
I think it would help if you simply think of the airbags as leveling out the truck and not so much as it helping the trailer itself. The WDH then does its job controlling sway and taking some of the stress/weight off the Raptor's hitch receiver and transferring some of that stress/weight to the trailer's frame.
As far as the process goes, I simply hitch up and set the WDH bars. Once I'm in the truck and ready to set off......since I've already previously measured how much air it took to get the truck level, I inflate the airbags to that pre-determined pressure of 30 lbs. I had the onboard air pump installed and in my center console there's a switch to add/release air. Next to the switch is a gauge that allows me to see how much pressure is in the bags.
MPG: I'm by no means conservative and don't care too much when I'm in town. For whatever reason that changes when you're traveling though. Becomes almost a game to see how good one can do really.
Anyway, with the 6.2 we were getting between 10.5 to 11. It really depended on the terrain. We tend to do a lot of driving in the mountains so we obviously lose a lot going up but also gain some coming back down. I found the sweet spot to be around 62 mph (we travel a lot obviously and have found that an extra 5 mph really doesn't help for s#!t when traveling distances. Stop to take a dump and all you did was waste gas.
---------- Post added at 10:27 PM ---------- Previous post was at 10:21 PM ----------
So, that is far more "realistic" than the guy with the 7000lb Aero that got 13mpg.
I don't get 13 empty!
He is doing something right, can't wait to see how he does it.
Not sure if you noticed, he said he's doing 77-80 mph. I'm doing just over 60 when towing. Big difference.
---------- Post added at 10:33 PM ---------- Previous post was at 10:27 PM ----------
I was always curious about this but when we originally got the trailer we were also towing with motorcycles in the bed. The adjustability of the airbags was pretty hard to overlook.
Did you by chance measure before and after? How far does it drop?
