FurryHungarian
- Joined
- Oct 27, 2016
- Posts
- 47
- Reaction score
- 31
I've already ordered a 2017 Screw and I'm trying to wrap my head around the GVWR and GCWR listed on Ford's site. The number don't add up. It can't tow 8000 pounds if the base curb weight is 5697 pounds (without options) and the GCWR is 12,000 pounds. Even if the truck was completely empty of passengers and cargo you will have exceeded the GCWR if you've attached 8000 pounds of trailer.
I plan on towing around 5300 pounds (Featherlite 3110 and track car) so I'm barely within the published weight limitations if I factor in my guesstimated weight of the truck with options. I max out the GVWR with me, one passenger, very little gear and 530 pounds of tongue weight at around 7000 pounds. Add my trailer and I've reached the 12,000 pound GCWR.
2017 Raptor Screw info from Ford's site:
Base Curb Weight (Lbs.) 5,697
Maximum Payload (Lbs.) 1,200
GVWR (Lbs.) 7,050
Max Towing (Lbs.) 8,000
GCWR (Lbs.) 12,000
There is no mention of a weight distribution hitch and how that may factor into the tow ratings but GCWR is what it is. I'm not trolling and I realize the Raptor is not the ideal tow vehicle. It's just my observation that Ford's max towing numbers are not obtainable.
GVWR (Lbs.) 7,050
GCWR (Lbs.) 12,000
