Power Steering fluid replacement
waddellw
Mississippi
My power steering unit has begun to whine and not wanting to mess up any of my truck would it help to drain the resivour and add new fluid, run it and do the same once or twice more.
I'd rather not disconnect any hoses to flush the system unless absolutely necessary
Would this be a feasible fix or at least an improvement at all? Rather not have the pump die on me going down the road!
Sent from my Pixel XL using Tapatalk
downforce137
In Diana
You could try it, but the pump develops a fracture inside and the fluid starts to cavitate and aerate the fluid. I used some Lucas p/s stop leak fluid and the noise was gone for quite awhile, till the pump failed all the way, while doing 4wd Donuts in the snow.
waddellw
waddellw
Mississippi
Hahah yeah I figured the pump might be messed up. I followed the steps to check the fluid levels and everything the fluid is between the high and low and still is the red color it should be. I will have to look into the stop leak and give it a try! Thanks for the input
