I have two 12" LED strips I'd like to install under both footwells up front and I'd like to tap into the dome light wire. Has anyone done this or could point me in the right direction? Really appreciate any help! I'd like them to dim with the dome if possible.
Thanks
dome supervision for a 2010 ford f150 is grey/purple at the passenger kick or at the sjb grey 14 pin plug pin 9
dome supervision for 2011-2012 ford f150 is grey/purple at the bcm grey 12 pin plug pin 1also can be found purple wire (puddle lamp) grey 26 pin plug pin 1
left front door trigger is green/purple
right front door trigger is white
left rear door is green
right rear door is yellow. all are located in passenger kick at the bcm grey 26 pin plug these are also the colors and location for the 2010 f150 as well
i recommend going to the puddle lamps or door trigger because the led strips you have are not going to be dimmable and you must use relays to make it work. also you need to make sure the led strips have built in resistors
