mike.s
Well-Known Member
- Joined
- May 12, 2012
- Posts
- 974
- Reaction score
- 639
Is anyone else running this setup? If you could check something for me, I'd appreciate it. i don't think mine is working perfectly.
When I select the Point-1 for my gps antenna and heading functions, I only get 1 blue bar in the satellites page (when I use the internal antenna, I get 7-8)
Also if you go to the point-1 settings under device list, my update rate is stuck at 1hz. It won't give me an option for 5hz or 10hz. Is this a limitation of the Elite 7m?
Despite these issues, the Point-1 is giving me better performance. It acquires my location quickly and my position accuracy is usually around 9-13 feet.
Thanks.
Thanks.
