Lost #5 CYL - Need Help
BlackRapto
Hi Everyone,
I need help on this. I have a 2014 Raptor, just shy of 22k. I was at a stop light and my trucks engine started shaking violently, followed by low RPM’s that I had to get on the gas for a bit to pull over to be towed. I towed it to a Ford dealer and they said cylinder #5 lost compression. They also mentioned that my intake system had water, and pointed out that I have a ram air system. (Pic attached) I can tell you, that I did not submerge the truck nor drive it in any puddles etc. I am trying to understand, why the wetness is on the opposite side of the filter? If you look closely, you can also see light dust everywhere and you can see some of the material pushing outwards in the center of the filter.
The dealer and they said the need to tear down the engine, if they find no water I am under warranty.
Your thoughts?
jokerz
Hi Everyone,
Your thoughts?
Dealers always play the blame game first. If you sucked in water you would more problems then on just one cylinder. Think about this. Air supplies all cylinders. your air intake isn't just hooked up to one cylinder.
Just my thoughts
Ironhorse07
Central, MT
Also, when/if any water passed through the filter it would be atomized and act more like water injection. Not sure of the actual physics of your particular filter but it is possible that water will not pass through, check with the filter manufacturer.
Vash
OK, USA
Regardless of the water, loss of compression is typically caused by a leak in the engine. This could be head gasket, rings, valves, or physical damage to the cylinder or cylinder wall. If you had injested enough water to cause damage, it likely would have caused issues with more than one cyclinder.
B
BlackRapto
I appreciate everyone's input so far. I agree with if water passed through the filter, it would most likely distribute across all cylinders. I brought that up to the manager, and he said "water can effect 1 cylinder". I called Volant manufacturer and explained what was going on and sent him the picture. The engineers pointed out pointed out everything we all have talked about and the fine dust all over (filter, SS clamps, inside of the box)
Has anyone heard this happening to anyone via aftermarket cold air intake system?
Your help is much appreciated!
jokerz
I think your reading into to much really.
I think the cylinder failed and ford is pulling your leg.
moosejaw
wow sorry to hear that is some scary stuff
whats the cost to repair that mess?
Crash33
They will find water (mysteriously) and void warranty... your move.
